Opinels are interesting and they do cut extremely well. But you have to screw around with them. A little sanding in the blade slot, and to smooth out the shape of handle is needed. Then you have to do some kind of oil or wax treatment to give the wood some water resistance. A mineral oil soak, or some melted snow seal or Vaseline jelly in the pivot area. I've used the Petroleum jelly and the better halts hair drier to melt the stuff in tot he wood, and I have to to where I can totally submerge the Opiel for 30 minutes with very little swelling of the wood. You can adjust the fit of the blade in the handle with either a large screw driver to loosen, or a hammer to tighten. The Opinels can be tinkered with to make them however you want.
Is it worth it?
I'm not sure, I have mixed feelings on them. On one hand, they are a PITA! But
on the other hand, they do cut like the dickens. They are very light weight for their size, and numbers 7 and 8 carry well in a pocket. They are cheap enough that they are like a semi disposable knife, used for those jobs where you don't want to mess up the blade on your "good" knife. But after a while of abusive and hard use, you find yourself having more respect for them. They will handle some pretty hard use, but not really hard. I've cracked one, and seen another one break.
But I like them for the same reason I fool around with black powder revolvers and traditional stick bows. It's kind of a blast from the past kind of thing. Did I mention they cut like the dickens?
Every knife nut needs an Opinel, and you should have one. But just keep in mind, it's like a general medium duty pocket knife. The blade lock is not that secure, so don't trust it like a modern lock blade. Most times I use my Opinel, I don't even bother with the locking wrong. I just use it like a friction folder, so I keep the blade pivot snugged up pretty firm. They are interesting. And they do cut like the dickens.
Used these two for years now.
