No. 5 doesn't have viroblocWhat's the issue? Fold it. Turn the lock, and lock it.
This is a brand new Carbone #8 after spending 24 hours in a potato.
I have a No. 8 with a lock, but I never use the lock. Never had a problem carrying loose in my pocket.No. 5 doesn't have virobloc
Opinel_line_setting by GaryWGraley, on Flickr
Untitled by GaryWGraley, on FlickrOh, that's good. My first np. 5 actually shifted horizontally ever so slightly before closing (think blade play) and the friction wasn't as good as on othersI have a No. 8 with a lock, but I never use the lock. Never had a problem carrying loose in my pocket.
The 5 does not have the lock. The 6 is the smallest locking Opinel. (I recently picked up a 5, a 9 and a 12, to fill in some gaps in the lineup.) If you are going to carry a friction folder, tune the action with a hammer so the blade does not flop around, and carry it tip down.What's the issue? Fold it. Turn the lock, and lock it.
This was my grandfathers’s knife. Well used.View attachment 2564260
Same here. I barely ever use the lock on my Opinel knives. I'm used to using slip joint knives and the last time I engaged the ring lock was for cutting down some blackberry bush vines with an Opinel No. 15 Slim. Sometimes being incredibly thin and slicey is a lot better than being a big thick hunk of steel.I have a No. 8 with a lock, but I never use the lock. Never had a problem carrying loose in my pocket.
I've done a 'drop point' mod on all my five Opinels (#10, two #9, #8 and #7) and never had a problem with the lock.I was doing the fairly common drop point mod to my last opinel and I guess I trusted the lock a little too much and BAM! the blade slammed on my fingers doing a pretty good cut.
I also remember cutting bread with Opinel 8 and the lock ring flies through the air and behind the radiator and I swear I never saw it again after hours of searching.
Never again.
I also cut all sorts of things with my Opinels (around the house, boxes, food, wood, branches, plastic, ..you name it) and none of those locks flied through the air.
The locks on all of my Opinels are solid and won't let the blade move even slightly. I guess those locks won't hold 100 pounds but they are holding just fine for all cutting tasks.
I can't imagine how the lock would fly through the air when cutting bread. Well; I guess if the bread was hard as a rock and you were trying to cut it with a spine of the knife and you put enormous pressure on the knife the lock would fail .... but ...
Say; were you doing the drop point mod on bench grinder or belt grinder and grind against the point of the blade?
Ehhh; you got me. Reading your post again I realized you were just joking.
I wasn't actually. I had opinel 6 that locked perfectly but plenty of 8's that did not.
I think it was the blade forcing the ring enough for it to pressure it and the push it out. It happened, don’t ask me how.Still can't understand ''flying lock ring'' when slicing bread.
Virobloc, does the viro-bloc-ing, ain't a vibroblade yet.Never had a problem with a vibroloc not vibrolocking.....
I can’t see it slicing bread, but after 1990, the lock rings gained a cutout on the bottom that held the blade closed if you turned the ring. That notch made it possible while opening the blade to lever the ring off the knife and send it flying. The first time it happened to me, I was in my son’s back yard, and never saw the lock ring again.Still can't understand ''flying lock ring'' when slicing bread.
