Hello,
It has been my understanding that, depending on what material is being cut, serrations can increase cutting efficiency up to 20% over a plain edge blade. This does not mean that it is easier to use a serrated blade, just that it will take fewer strokes to sever the material. Cutting with a serrated blade actually takes more effort per stroke becasue more material is being cut with each push/pull. How much of this increase in efficiency is due to the serrations and how much is due to the fact that serrations tend to be ground at a steeper angle than a plain edge blade?
It seems like the aggressive Spyderco style serrations have become more or less the industry standard. While these are very effective, they are not very smooth and can lead to more ripping than cutting. Cold Steel has a serration pattern with much finer teeth. They seem able to cut much smoother than the more aggressive pattern yet few other comapnies have a fine serration pattern such as this. It's like the difference between cutting with a bow saw or a hack saw - both get the job done but each has a different feel. Why don't more companies offer a fine tooth pattern?
I have seen a lot of nice, smaller blades that IMHO have been ruined by the inappropriate use of serrations. I believe that blades under about 2.5 inches shouldn't have any serrations on them at all. There just doesn't appear to be enough cutting surface available to make the serrations useful. But a similar plain edge blade may make fine push cuts or be a great slicer.
Blades in the 2.5-3.5 inch range seem well suited to a fully serrated edge, but not a combo-edge. The combo-edge seems to leave too little of both the plain edge and the serrated portion for either to be really effective. Blades of 3.5+ inches seem large enough to accomodate either a combo-edge or full serrations.
The end result for me: I like small blades to be plain edge, medium blades to be plain or fully serrated, and large blades plain or with full or partial serrations.
How about you?
Later,
MBS
Nevermind the dog...beware of owner!
How about you?
Later,
MBS
