If it is a well used sebbie, take it apart and mark where the blade hits the stop pin, then spin the stop pin about 25% so that it hits a different spot and see where it locks up.
As nyefmaker states the slightest change can move the lockbar from 50% to 100%
If that helps then just mark the stop pin so that you can get it put back together the same.
As for the sticky lockbar that is quite common with the regular models, you can send it in and have them look at it, I had to send in a few of mine to get them "unsticky"
They remedied it and the turn around time was about 10 days at the time.
I just reread your post and didn't see the word "regular" sorry about that,
It is actually quite UNcommon for the 21's to be sticky, I would def. send it in if after you take it apart and inspect it and put it back together if it is the same.
Good luck!
