- Jul 31, 2015
Thanks Stacy. I will check it out.
When I measured the ohms, I believe it was 8-9 ohms per coil, so should be 16-18 ohms total, but I will make the connection improvements Stacy suggested and test the ohms from those points.
To clarify, there was only a delay the very first time, as the coils were smoking, with maybe a few second delay. The subsequent two times, it was immediate.In his initial post he stated it came on, the lights lit, the coils started to heat, and then the 20 amp glass/ceramic Buss fuse blew.
That could not happen with a direct short. In a few milliseconds, the breaker would likely blow as well as the fuses.
With the fuse blowing with such heat as to break the glass/ceramic - after the coils started to heat, it would indicate an over-draw from the coils.
BTW - If you are using glass fuses, they aren't what you want here. Use ceramic fuses.
There is no neutral, two hot legs and a ground.
