Im running into an issue reprofiling with the grit wheel. I have been using the polishing wheel so far for the most part. My edges have been getting inconsistent and I realized ive been polishing at 20 degrees when my edges are 23-24 (also some just need metal removed). Most of the time I corrected the angle by feel, and got a hair popping edge, so it took me until now to notice. So I have started to try reprofiling/grit wheel on my favorites, but find I can't apex the edge unless I run an angle 30 degrees plus. For example I ruined the coating/looks of a Spyderco Military trying to reprofile to 20 degrees, and then 25. I believe the edge was too wide/thick behind the edge for a wheel to hit, and I could never finish grinding the shoulder down to the apex. Progress stopped at 3/4, I gave up and did a 30 degree edge which whittles hair. Now im trying a Manix which is thinner and about 25 degrees already, it seems like the same problem is developing. I get a grind mark right in the middle of the edge, so the angle is correct. Also I use an angle template so I make the exact same consistent grind line every pass. The problem is they are narrow and don't hit the shoulder or the apex. It could be if I keep going it will eventually hit the entire edge, but I can't ruin any more nice knives. I don't have this issue with my customs which are thin behind the edge, or say an Opinel or kitchen knife at 20 degrees. What is the lowest angle you guys have done using wheels on a blade of average thickness? Cheers!
