Hi Don,thanks for taking the time for your reply.Two different bevels sounds interesting.I guess the moisture in the potatoes woud be a big variable, and yes I would be interested in what Mario has to say on the percentage of flat/convex.Thanks again.Lu
One thing to note is that while potatoes are a good test overall, the real test is to skin them and leave them soaking water in the fridge overnight.
is there anything about cutting technique that causes food stickage? or is it all in the grind?
DR....
Why? Does that make the tater "stickier" (my first guess, not having heard that before) ? I'm not being a smart-alec, it's an honest question![]()
It actually does that opposite. Soaking taters is an established technique to wash the natural starches off the surface. The starches are what make the taters, pasta, rice stick and clump together. Restaurant a soak French and change the water multiple times before frying. ***NOTE - make sure to dry them throughly before frying unless you want an explosion.
It actually does that opposite. Soaking taters is an established technique to wash the natural starches off the surface. The starches are what make the taters, pasta, rice stick and clump together. Restaurants soak French fries and change the water multiple times before frying. ***NOTE - make sure to dry them throughly before frying unless you want an explosion.
My questions: Has anyone every tried to determine whether a smooth surface, 1000/1200 grit or a bead blasted surface has lower stiction? Also, has anyone ever tried to determine if horizontal or vertical sanding marks make a difference in stiction?
