That's exactly what I'm wanting to get, thanks for the feedback. Have you connected it to the phone app? How do you like it?
They have a switch you can get that will turn off power as soon as you open the door... I think that's what I'm gonna do probablyI've had an evenheat for 3 years and have been overall pleased with it.
I have learned to heat treat coupons to try to dial in the HT protocol because there can be variability between ovens in terms of actual temp.
The other thing I have done because of the concern regarding the exposed elements is that I have placed 3 furnace bricks inside my oven to create an "oven inside an oven". I never have more than 2 knives in at a time so it's ok that it takes up space. I don't know if this really mitigates the problem or not but it makes me feel better that they're shielded.![]()
Interesting... a few questions:I have not used a Paragon. I have had my Evenheat KH418 for about 8 years. I do not do anywhere near the amount of blades as many other makers. But I have had to replace the control board of my Rampmaster lll and thermocouple. It still acts glitchy sometimes.
My other thought (rightly or wrongly) is that having insulating bricks closer to the knives and taking up air space may provide a more even heating environment. I'm not an engineer so I may be way off.They have a switch you can get that will turn off power as soon as you open the door... I think that's what I'm gonna do probably
There was mentioning of muli-zone kilns in the thread. Interested to know when that would be of benefit to us?
One thing I have been pondering, after hints from a pro, is to place a separate K-element, hooked up to a separate thermometer, next to where the actual blade is in the kiln. To get a more exact reading of temps. Any thoughts on that?
Wouldn't that require either a much more expensive PID (if building the oven yourself) or multiple PID's and wiring for multiple sets of elements? Sounds like a great idea for a larger oven like for swords but might be a bit overkill for a knife making oven. If it is just for taking temps it wouldn't be too bad but for multi zone heating it would be a good bit more complex.
If you do make sure to post a tutorialOh, I wasn't thinking for multi-zone kilns. Just for a normal single-zone. Sorry if I wasn't clear on that.
I would be intrigued to know the actual temp by the blade during the HT process.. Set-up should be pretty easy. K-element, thermometer, drill.. Not too expensive either. Yeah, maybe exaggerated nerdiness...but there is plenty of that on the forum![]()
I went with evenheat for one simple reason. They're about 1 1/2 hours north of me so I could just drive up there and save shipping cost.
Its been good but there are some things that irk me.
I got the TAP controller and it has a hard time registering the touch of my finger. Maybe I got a bad one but it can be maddening trying to program when it only registers every 10th or 20th touch. Yeah, 10 or 20.
The other thing is that after I run a program and the oven cools down the temperature it shows is ALWAYS 20-25 degrees warmer that it is in my shop. I've left the door open for days and it never shows the correct temp. I have to unplug it for 20 minutes. Then when it's plugged back in. Only then will it show the correct temp.
I also agree with others that test coupons must be done. When I followed established recipes I got sub-par results. After dialing in the correct temps for my oven I got much better results. And I do have a hardness tester which made it much easier.
