- Aug 2, 2009
oh man, good points!! have you contacted Evenheat? if so, what did they say?
They were somewhat helpful. They immediately sent me a new thermocouple free of charge. Although it didn't help.
Since I am relatively close they said I could bring it up and they'd take a look at both the temp and tap issues. I never took them up on it. Once I got it dialed in the HT was fine after I reset the initial temp by unplugging it. I still have to reset every time.
Also, all my programs are saved so it only takes a couple imputs to start..still 20 - 40 touches. I will say that there are times where lately that it has been registering my touches after just 2 or 3.
Hi Mike, was just browsing doing research for a new knife kiln I'm designing (we are in Australia - it won't be being sold in the US) and saw your post about the troubles with the TAP controller - they are crap... but fairly easy to fix your problems. I don't know how to message you directly - so I'll just post it here: First up, please upgrade your firmware to the latest version if you can. If you can't because it won't register your finger its harder but not impossible. Once you have upgraded your firmware just turn it on and off 5 times (full boot up) without touching the screen and it will open the diagnostic which lets you recalibrate your touch screen. We have also found some issues with two other evenheats using the TAP controller where the wiring to the controller screen was rubbish and just needed redoing - which fixed all the issues those kilns were having. Every wire that goes to the screen is either low or no voltage, so you are safe to take a look - unplug it first just in case.
hopefully that fixes it - the TAP controller was a great idea, just really poorly implemented.
Cheers Ash.
Thank you Ash. I will definitely try this. I'm comfortable rewiring if necessary.
