Looking for a new blade for christmas. Looking at these two. Which lock in your opinion is better for closing and a quick put away? I know both have the same blade material and handle material. Which has better ergos? Does one slip into the pocket and dissapear better than the other? Build quality? Also, which blade is more practical in size? [...]So, which do you guys think is the better blade?
I close both the military and para2 in nearly the same way, using my thigh on the spine of the blade to push it close as I disengage the lock (with my thumb for compression lock since it's on outside edge, index finger for liner lock since it's on inside edge). So there really isn't a difference for me in speed with either. However, the compression lock did come a bit "sticky," for lack of a better word, so it does take a bit more to disengage the lock (doesn't bother me much, and less now that's it's wearing in) than the Military straight out of the box. I guess in that case the Military would be better straight out of the box.
Ergos are
excellent on both, I prefer the Para2 because it's just as comfortable as the Military, but in a more compact package. The one thing I do notice, is the shortened arc in using the thumb-hole on the Para2. On the military, I can swing the blade out easily from a couple of different grips. With the smaller Para2, I can still swing the blade easily open when using my thumb and opening into a normal saber grip. But if trying to open with my pinky into reversed grip, it's not so easily flickable for me yet. Not a big deal, just something I noticed, and not really a surprise on the smaller knife.
I don't notice much of a difference in pocketing. They seem to be equally visible and to slide in equally well. The military may ride a little higher, but not enough to make a huge difference in my opinion. The Para takes up less room in the pocket of course. But the military really doesn't take up much room either, with it being so thin, and it really is incredibly lightweight for such a large knife. I have absolutely no problems EDCing it in jeans, shorts, or slacks. As the others have said, the Military really does just disappear in the pocket. And it really doesn't feel much heavier than the relatively dense Para2 with its full liners.
Build quality? Shrug, identical for me. Both knives were in tip-top shape when new, no flaws.
As for size, really, only you can answer that based on your intended usage, legal restrictions, preference, etc. The Military really is a big knife to me, and I find the Para2 to be just right.
The better blade? Subjectively, for me, based on all around usage, it's the Para2:
*Retains absolutely incredible ergos while being compact
*Perfect blade length for my EDC needs (large enough to cut and slice well, but short enough for fine manipulation and fine work with the tip)
*Compression lock seems less likely to fail with unexpected rough use
*And now, with the protruding tang eliminated, looks just as good as the Military
BUT, I don't plan on selling the Military anytime soon. Sometimes I swap it in to EDC on a whim, or take it out on short strolls in the woods or other outdoor activities, or assign it weekend knife duties. Aye, 'tis an old friend
