And how exactly did you achieve this pattern?Forced a patina on this GEC last night.
French's Mustard. You can use any mustard as long as the main ingredient is vinegar (acetic acid). With larger blades I would use a small brush or Q-Tip to apply the mustard in my desired pattern. Because this is such a small blade I applied the pattern using a toothpick that I dipped in mustard. I then let the blade sit overnight (I applied the mustard pattern at 1:30 pm the previous day, went bass fishing the next morning and washed off the dried mustard residue when I got home around 10:30 am. What's left behind is the vinegar (acetic acid) etching in the blade. I sharpened the Spear Point blade prior to the forced patina. The smaller coping blade came from the factory nice and sharp. The factory edge on the spear point left a lot to be desired; now it is shaving sharp.And how exactly did you achieve this pattern?
French's Mustard. You can use any mustard as long as the main ingredient is vinegar (acetic acid). With larger blades I would use a small brush or Q-Tip to apply the mustard in my desired pattern. Because this is such a small blade I applied the pattern using a toothpick that I dipped in mustard. I then let the blade sit overnight (I applied the mustard pattern at 1:30 pm the previous day, went bass fishing the next morning and washed off the dried mustard residue when I got home around 10:30 am. What's left behind is the vinegar (acetic acid) etching in the blade. I sharpened the Spear Point blade prior to the forced patina. The smaller coping blade came from the factory nice and sharp. The factory edge on the spear point left a lot to be desired; now it is shaving sharp.![]()
