Well, some of you may think I haven't done much on this project recently, and you'd be right.
But, I have been doing an occasional welding sequence on the billet that will become the hilt fittings. Today I did the last weld, and started patterning and forming the pieces.
The billet that the fittings are made from has 150 layers.
The steels used in the fittings are O1 and L6. The reasons for this are that these steels are deeper hardening than the ones I used for the blade. The fittings are going to be heat treated, because hardened damascus has better contrast than annealed (soft), and if I used shallow hardening steels for the pommel, then there would likely be splotchy areas where it didn't harden, because it's much thicker than a blade. Anyway, it's a possibility, and I don't want to risk it.
Also, being different alloys, the fittings will have a different look than the blade, and I think that's good.
The upper and lower guards will both be twisted, and the pommel will be random.
I didn't get any pics of the welding and drawing out steps, but if you've read the rest of the thread, you should be familiar with those processes.
Here is the wider of the two guards after twisting:
After flattening:
After bending:
Here it's been cut off of the parent bar:
And here is the block that will become the pommel:
