Peak LED Utility Inspection Light
ndmiller65
Feedback: +50 / =0 / -0
This light is in excellent shape. I’d like $100 shipped in USA. Paypal preferred but can take Venmo. Specs from manufacturer.
1. Flashlight Industry Standard Dimensions: Head Diameter 1 ¼“ diameter Max, battery
compartment 1” diameter Max
2. Flashlight battery compartment able to stand vertically
3. Tail switch to be dual position a) Turn flashlight on or off .. b) Momentary on – release off
4. Tail switch to be protected from damage from a 12 foot drop onto concrete floor
5. Tail switch designed to prevent accidental activation
6. Head to incorporate anti roll feature not to exceed 1 ½” diameter
7. Head to be protected from damage to window and bezel from a 12 foot drop onto a
concrete floor with and additional security ring
8. LED electronics to be potted with Thermal Epoxy
9. Rear of head assembly to be sealed with Epoxy
10. Head window to be scratch resistant clear polycarbonate plastic
11. Head window to be sealed with quad style o-ring
12. LED light source to provide maximum candlepower throw utilizing a Cree XPL-V2 High Intensity LED
13. LED to be current rated at 150% of input current to LED
14. Electronic circuit to limit current to LED independent of input voltage range of 3.6 volts to 12 volts DC
15. Bezel, head, battery compartment and switch tail protector to be machined from aircraft grade aluminum
16. All aluminum parts to be anodized Type III black
Let me know if you have any questions. Thank you!
Still available. Runs on 18650 cells or anything else that will fit in the tube up to 12 volts.
