- Dec 3, 1999
Time standing in front of the grinder is #1.
And I want to point out that you need to be VERY careful trying to true up plunge cuts with anything that only makes contact in a very small area... like round files, cratex, etc. They certainly CAN be used, but the problem with this type of clean up is that many folks try to do too much with them. Since they only make contact with a very small area at a time, it is VERY VERY easy to create a wavy surface.
You usually won't see it unless you have a trained eye and great lighting. You can take a blade that has had the plunges filed true.... but the overall bevel not truly feathered into it... wave it around in the light and you will see the light bounce off the wavy surface.
If you are just LIGHTLY removing a few pesky scratches, then stuff like cratex work well.
If you are dialing in the plunges to make them dead nuts even side to side, then I would recommend a steel plate or block that's at least 3" wide, with a radius on the edge that matches the radius you want in your plunge.
You use PSA paper, or spray glue paper and then apply it to the block. Then you can use this to dial the plunges in.
It works VERY well.
I can get them even right off the grinder, but I still use this method to clean the plunge up. I clamp a carbide faced file guide on the ricasso when I do it. I didn't in this photo, but I usually do now. It only takes about 10 minutes total, and makes the overall hand finishing go much easier for me.
It works VERY well.
