there are plenty of combat and field use testimonials on the various Busse forums. Mine among them. But, since I was never in Viet Nam... they probably don't hold water.
yeah well, me neither. and i already have a canteen to hold water, so i'd be intrested in reading 'em anyway. if you can point us in the appropriate direction...
In regards to removing the human element, this while sounding "scientific" is in fact the opposite, as you have now designed a test which the outcome doesn't allow useful predicitions.
cliff i disagree completely. if this was indeed the case, then these same points would be equally applicable to the standard busse lateral stress test. it could be argued that these tests are invalid, as we are unable to predict the radius of the car door sill, that our hapless survivor is trying to force open.
i believe that jerry's requirements were for tests that were easily specifiable, and repeatable "live". surely in order to produce lots of scientific sounding numbers the ideal is to remove the human element and eliminate unquantifiable variation. exactly how a test method is carried out, is not as important as ensuring that the samples being examined are tested to the exact same protocols. it matters less that busse carry out lateral stress tess in a vice, and fallkniven do theirs about a radius. the comparison is only valid if both products are tested using identical methodology. you can, as zius has suggested, apply some clever maths to extrapolate the results of one test, and predict how the sample will perform in the other test. (to be honest i'm not that fussed, my maths ain't that good.)
there is a simple truism that applys to engineers and scientists alike. "if you can't repeat it, you haven't done it"
i still don't know exactly what the cutlery and allied trades machine does. the test i envisaged was a sort of automatic guillotine, the knife blade is secured to an arm, one end of which is secured at a fulcrum. as the arm moves up a line of rope is feed through under the knife blade. a pneumatic piston drives the arm back down and the force required to sever the rope is measured and plotted. the arm goes up the rope goes in and so on. there are finer points that could be haggled over, you could have a slicing rather than chopping motion, but with movment about the fulcrum you get a degree of slicing antway. do you have a chopping board as an end stop. in all cases the point's at which the pressure is measured and torque applied will be the same.
this test effectively compares the cutting ablity of the samples. this includes the efficiency of the geometry, and edge holding. edge holding is dependant on the steel and the effectiveness of the heat treat, as it applies to that steel. so this test covers those points, and the busse lateral stress test covers robustness.
jerry has commented about other manufacturers claims not having factual or statistical basis. well, a man from sog once told me that their knives were good "stabbers", unfortunately, according to the regs, i'm not permitted to stab my scouts
so it's rather a moot point for me. but on that note. other tests i'd like to see developed are:
ease of penetration into meat or a meat substitute, covers both combat and filleting fish requirements.
chopping ability, to include edge retention/deformation. this could be hard to do.
most acute angle of slicing ability, covers woodworking skills for survival, and affects chopping ablity. (try chopping with both a cs hawk and a gb axe, you'll see what i mean.)
so, how're we doing for developing a range of class "A" factual/numerical tests then? when do we start developing the class "B" user driven subjective testing program eh?
cheers, and.
