Today i had the chance to test the new edge in the woods again;
As expected the knife cuts way better thanks to the reduced edge angle, not only paper & cardboard, but also all kinds of green & dry wood.
Bite is also still very good.
However: after chopping a deep V-notch in the edge of a "forest bench" (a piece of seasoned oak timber on wooden blocks: very hard stuff) there was microchipping (but almost no flattening) almost along the entire edge.
Judging from the scratches in the bevels at least part of it was due to minute small sand particles trapped in the wood surface, so that would possibly also have happened on larger edge angles.
Most of it was only visible when seen through the magnifying glass of my Victorinox SwissChamp, but some of it could also be seen by the naked eye (with good lighting)
Shaving hair on the back of my hand or my calf is also not possible anymore, but the knife still cuts all kinds of green & dry wood very well.
Copy paper can also still be sliced, but you can feel the microchips.
In a few days i will enlarge the edge angle to an even 30 degrees with the same grit 60 Rubber Wheel finish, and then i will find myself a nice piece of seasoned oak again (this time without the sand particles) to do some more testing.
It seems to me that any reasonable knife with a good HT in M390 is going to perform exceptionally well. As long as you don't do something silly with the thickness or grind the steel really seems to perform great in most all blades from a para 2 to a medium/large fixed blade like this. Seems to me it wears just like S90v, but with even more stain resistance from the super high Cr...I'd be surprised to see any blade M390 isn't great in.
M390 is an excellent steel, a more complex steel really with a very high alloy content that provides a number of properties such as excellent edge retention, highly stainless and reasonable toughness for a stainless steel.
However is not chippy even at high hardness and will take a very fine edge, it's an aggressive cutter also.
You got me - I just ordered one of these!!
Thanks for sharing...
Ben
I just got back from two weeks in the field with my unit and I used this knife as my primary knife. Held up very well and sat for three days in constant rain on my kit with only one small spot of rust on the blade that wiped off with kroil. I battoned my way through a hogs pelvis and ribs with it an the edge was undamaged. Couldnt ask for more from this knife.
