Cutshaw
Moderator
- Aug 15, 2004
Well thanks for the sentiments, guys. Best stay away from the Practical Tactical forum, where they discuss using knives on people.
Whoa, there Poss.
Cliff Stamp said:Does a higher polish lose cutting ability on the flesh? I would be concerned about stress lines from the scratches and maybe consider a fully polished edge and then a very slightly secondary coarse edge.
Yeah, this sort of thing may be "par for the course" for me, but I get the feeling he was referring to coon hunting with a knife to be unusual.Not really, he has described doing it on a fairly regular basis in the past, breaking one knife because of it, and grinding a large amount of metal off another because of accumulation.
At the risk of stirring up things, there is a lot in this quote I can agree with. If I had given my old knife some real testing before it was done, I probably never would have bothered putting in all the work finishing it. I would have never chosen to use stainless steel on that old knife if I'd seen some destructive testing. (or read steel spec sheets instead of knife magazines.Why is it "understandable" if it happens in real use, but not if you do it to simulate it? Would it not be better to understand what your tool could do before you are actually forced to depend on it? ...Beyond this, lots of large knives while not designed to actually be used to cut rocks and metals, are designed with such impacts in mind as accidental high stress impacts. So again why would it be unreasonable to actually see if the tool can handle it by just trying it out, instead of waiting for it to happen which could risk gross failure and leave the user without the necessary tool which he depended on?
Jeff Clark said:Given your situation I might try something like a pair of nunchaku for the job. I made my own out of a couple pieces of steel electrical conduit connected by cable. These have speed and high impact without risk of getting dull or breaking. You could tweak the weight to be optimum given a coons weight and fur.
That is interesting, I cut a lot of cured pork fat, which has a very thick and hard outer rind and a very sharp highly polish knife glides right through it, the same holds for the freshly killed pig. Maybe it has to do with the hair which is acting similar to tougher rope which can cause polished blades to just skip over the surface.the possum said:...because of the skin.
the possum said:Paddling Man-
In that context, I can understand your reply. I am serious with this thread, but now that you mention it, I can certainly see where you'd think it was one of Kliff Stump's humorous reviews. I apologize for my assumption.
His website isn't listed in his profile or sig line. Can someone point this out, please?Cougar Allen said:Some of you guys could have a look at Possum's website..
Good stuff possum, I'm in Western Ky, we've all got to get together sometime.Paddling_man said:No, sweat. It was damn funny, though!
Where in So Il are you? I lived in Knoxville, TN (actually, Maryville, twenty minutes from the Smoky Mtn Nat'l Park) for about 15 years before I transferred to St. Louis five years ago. I've traveled thru So Il numerous times on my way back to visit with friends and paddle whitewater kayaks on the Plateau and the Ocoee.
Cliff Stamp said:That is interesting, I cut a lot of cured pork fat, which has a very thick and hard outer rind and a very sharp highly polish knife glides right through it, the same holds for the freshly killed pig. Maybe it has to do with the hair which is acting similar to tougher rope which can cause polished blades to just skip over the surface.
-Cliff
Knifetester said:Yes, I would imagine it is the fur that causes blade impediment, not the skin. Skin is easy to cut, relative to most materials, I have cut myself by accident enough times to know that.
Jeff Clark said:The way that hair or cloth can bunch up, mold to a blade, then roll or slide with the edge can have a huge impact on hacking or slashing efficiency... The sort of ragged peeled edges left by a file cut through bunched up terry cloth extremely well... I suggest you try a file edge.
