- Nov 14, 2001
Good work, Bruce! Congrats!
Originally posted by beknives
...chop the two 2X4's for the test,no problem and still shaving,now I cut the rope for the real test,cut clean first swing,Still shaving...Now just to make sure that the edge would still hold jerry said to cut the two 2X4's again which I did and even cut through a knote on the second one.Now I had went past the minimum requirements on the test and the knife was still shaving...On to the vice,Jerry had the edge ground of do you mean "off" the blade so if for some reason something went wrong sharp pieces of steel wouldn't be flying around.Now he clamped the blade and had me bend it,When I reached 90 degrees he said to stop,checked the edge and not a crack to be found..
I used 5160 normalized 4 times after forging,ground,normalized 4 more times,edge quenched once,and drawn back twice in the oven...
