JT, that is an excellent drawing. Much better than my original sketch.
ib2v4u,
This setup allows the forge to cycle from a soft burn which is set below the target, to a higher burn which will bring the forge to a bit above the target temp. When properly set the flame cycles back and forth....but does not go out ! This stops the popping and whooshing that an on/off system has. It also offers far tighter regulation. With the two stages properly set up and balanced, the forge atmosphere is always constant (reducing/oxidizing) , thus reducing scale. In a standard single stage blown forge, the gas is shut off by the solenoid/PID , but the fan still runs at the same flow rate. This floods the hot chamber with lots of extra oxygen until the gas is turned on again and suddenly ignites in the oxygen rich chamber with a big whoosh.
I added a stop switch on mine that will shut off the power to a primary solenoid which is mounted in the gas line before the split into two stages. Hitting this switch will stop all gas flow instantly. The switch controls the power supply wire right after the main power switch, so it stops the fan and shuts off all power to the PID and solenoids. Hit this button and the whole forge stops dead. Not really needed, but a good emergency shut off in case of a fire or spilled quench tank. All that it required was another solenoid and a big red SPST push switch.
I'll repeat the setup procedures ,for anyone who didn't read the old posts.
Once the unit is built and checked for wiring errors and gas leaks.
Program the PID for a temperature about 100 degrees above the usual target desired , I use 1600F.
Turn the gas regulator to about 3-5 PSI. (adjust up as needed to maintain desired temp)
Open the LOW needle valve half way or more.
Turn the LOW fan control to full.
Both HI controls should be off.
Open the main shut off valve and light the forge.
At this point it will be running only on the LOW stage. Adjust the valves as needed if the flame mix is way off.
Once the forge is up and running , let it get fully heated. It should take about 15 minutes or so for most forges.
Adjust the LOW air and gas valves until the forge holds at around 1400F. Adjust the air control to get the chamber atmosphered desired. I like a neutral to ever so slightly rich forge atmosphere. Now the LOW stage is set.
Up until now the PID hasn't been able to do anything because the HI control valves are off.
Open the HI needle valve about half way.Then turn the HI fan control up about half way,too. Let the forge slowly rise in temp, adjusting both HI controls as needed to maintain the forge atmosphere and have the temp increase. As it approaches 1550F trim the HI gas and air to get the flame as close as you can to balanced. When the temp reaches 1550,Adjust the valves so it holds about there.( the PID is still keeping the HI solenoid and HI air open). Once the temp is steady at 1550F, change the PID program to 1500F.
Re-balance the LOW air setting if the air mix seems out of balance. When it cycles back on to HI again, re-balance the HI fan again if needed. A couple tweaks back and forth and the forge should hold at 1500F and the flame should stay pretty much balanced all the time. ( Note that the flame always stays on.)
Now you can set the PID to any normal temp between 1400F and 1600F and have it hold to a very close tolerance with a perfect forge atmosphere.
Higher or lower temps can be held with adjustment of the ranges used. It is best to keep the overall swing about 150-200F, for the tightest control. Adjustments for higher or lower ranges are simple once the procedure is set up the first time.
Stacy
