- Oct 6, 1998
Jeff,
I use a pair if 1" x 12" x 12" 6061 alu plates. At one time I was using a 6x18 magnetic chuck and it worked ok for steels other than CPM. When I started using 3V and S30V, the Crucible guys recommended the aluminim for a much faster quench.
I grind after heat treat so no knowledge how some of the wierd grinds would work. Tapered tangs and long distal tapers with a flat grind might present a problem.
I pull em out, throw em on the bottom plate, drop the top plate on top, put a 25 pound piece of steel on it and then use 4 quick squeeze wood working clamps.
An engineer friend of mine told me the formula for figuring up how large the plates should be in relation to blade size. It was something like Pi are round, cornbread are square iirc.
