Ankerson
Knife and Computer Geek
- Nov 2, 2002
I have been wondering about primary grinds and any effects on rope cutting. Since the rope is cut as individual strands, not even the full thickness at the top of the edge bevel would have an effect on the downward force of the cut. But depending on how the rope is held, there would be some compression of the rope that is in contact with the surface of the primary grind. The thinner/more acute the primary grind, the less of the downward cutting force would be translated to a force perpendicular to the blade surface, and a compression normal to that.
Something else that can affect perception of coarse edges is that the velocity of the blade as it moves in a slicing motion increases cutting ability and reduces effort in the cut. If you have a tendency to slice with coarse edges, then you may think it is the edge finish helping things out when it is also the slicing action itself also providing some benefit. But coarse edges also provide deeper cuts with less downward force in a pure slicing action, and polished edges cut more easily in a true push cut.
That's why I separated the Custom knives from the factory blades, to keep things apples to apples.
Most factory blades start at 15 LBS of downforce with the Polished edges.
