Here is a little experiment to try. It falls under the polished edge category. Sharpen like you normally do, polished, or not, cut something till the blade looses the bite, cardboard or rope. make a strop out of a piece of flat wood and strip of leather (an old belt from the thrift store works good). Glue the leather to the stick with Barge Cement or equal. Rub some abrasive into the leather. I use the dross off the fine SC Norton Stone. Just work the leather into the stone to pick some abrasive up. Back stroke the blade a few times with light to medium pressure, check the sharpness during the process. I have found I can almost restore the edge 100% this way. You can get away this at least once with out going back to a stone. It is quick and the wood and leather strop is a lot lighter than a stone. Makes it very nice to carry in a pocket or pack in the field. This works with all the steels I have used so far. Very effective on S30V, ELMAX, M390, S90V. This may not be new information to some but may be a hint some others would find useful. Phil
Hey Jim,
When we first began making knives in the early 80's, we'd already been making sharpening stones for a while. Steel was developing back then but had not come as far as todays steels so better edge retention was always sought.
We learned that a coarse edge would cut more aggressively but a polished edge would stay sharper longer. At the time, the solution was a highly polished thin serratied edge. You might polish up a thin serrated edge (the sharpmker will work for this) and do your rope test with a good steel that has a polished serration.
sal
