You folks have not learned a thing from Bear Grylls' 'Man vs Wild' show... carry a good MasterCard!
Stainz
Mine is: use little visine dispenser (fits easily into an altoids tin) and fill it with bleach. It dispenses drops easily and you can add bleach to water to kill any organisms. I think it is 2 drops of bleach per gallon, but I'm not sure. That one little bottle will help you clean alot of water.
My piece of advice is "KNOW FOR SURE!" Not to pick on southbeachlaw but the knowing how much bleach to use could either make you sick, or prevent you from becomming sick. The generally accepted amount of bleach to use in unknown water is 2 drops per "quart". Then if you do not smell residual chlorine in the water, use 2 more drops. The chlorine in sodium hypochlorite (makes up just over 5% of household bleach) is an oxydizing agent that will destroy bacteria if there is enough available to do so. If you put 2 drops into brackish water, the chlorine will complex with the organic material in the water long before it has a chance to kill the bacteria.
Using 2 drops per gallon would only anger most bacteria and likely leave the pathogens to make your survival take on a new meaning of misery.
So if you carry something, anything, in your kit, know how to use it or it's just dead weight. (southbeachlaw, still a good thread with lot's of good knowledge!).
