Finally here
Got some new Toxic Green shoes for the ole CTS-20CP Para-2 (made by Allen Putman). I highly recommend them:
I saw you post this on OSA EZbake, very nice!!!
Excellent scales, sir!
What procedure did you use to remove the lanyard tube from the original PM2 scales? Was it easier said than done?
This is the second set of custom scales for this one, and I had removed the scales a few times before that when attempting to dye them. First time is always stiff and tricky - but I use WD-40 or some similar breaking lube to get them free and rotate and gently put pressure on them until they come loose. They all fit differently (I've done this to 4 or 5 of my PM2s) depending on flare of lanyard tube and machining of scales, but these were surprisingly tight in tolerances while still being easy to get on.
