RobertHankins :
First off I appreciate any maker (or anyone else) sharing work they have done with knives, however as Cougar noted there are some problems with the way the above is being interpreted mainly because there is nothing used as a reference.
Someone care to step up and pound one of there production knives thru some steel.
I have done it many times including on harder and stronger materials than 1/8 mild steel. Consider the hardness of the steel as opposed to the hardness of the knife. Why would you expect the knife to get damaged. It cannot get impacted and considering the obtuse tip geometry there is no way it is going to deform.
When you are doing these things as Cougar noted you want to do it with a few other knives so as to get an idea of just how "impressive" a task is actually being performed. Some things can be very misleading if you have not done them before. Here is a shot of a Busse Basic after being used to cut the drain out of a sink :
http://www.physics.mun.ca/~sstamp/images/basic_sink.jpg
That club was used as a mallet as it was far too tiring to just stab and wrench it through by hand. The blade took little edge damage, some but not enough to see it on the picture. The tip was not effected however it had been flattened before by impacts off of rock. Does this actually prove anything. No not by itself, as unless you have done similar things with other knives you can't judge the strength of the performance.
I had a friend awhile ago do a demonstration that he was told by a knifemaker as to the quality of his heat treatment. He put a nail (common 3.5") in a vice and pressed a blade through it. I then took a 5$ fillet knife (440A stainless) and then did the same thing. Even cheap cutlery steel is far harder than the steel used in common nails, sheet metal etc. .
Consider this, Tom Johanning has driven his TAC series through steel many times (3/16" diamond plate steel) :
http://www.survivalknives.com/dplate.gif
yet when Dan Kohlstrom used two of the blades two tip fractures were generated :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=89352
I bent the tip of a TAC-11 awhile ago doing pretty much the same thing. While it maybe doesn't sound as impressive to some, digging in wood is far harder on a knife than being pounded through a sheet metal or even plate. So are lots of other things, some which are directly related to the tasks that the knife could be called on to perform. For example contacts off of bone.
Take some thick bone stock and do hard cuts into it while it is moving (swing it with a 10-20 lbs weight hanging from the end). Use both the edge and the point. You will see the effects of hard contacts as well as violent snaps across the edge. These will generate far greater pressures and forces on the knife than driving the point through sheet metal or even steel plate.
-Cliff
