Is there any PG W2 available online? Looking for some 1/8" or so. Thanks
Has anyone heard the why of "higher than grain refinement" amount of vanadium and the 0.80% (as opposed to half or less) manganese?
Mike Krall
Sounds like a great knife steel. But the high manganese is not so good for hamon activity.Some good news might be that Crucible is supposedly going try to have their new baldesmithing steel for sale at Blade. Dr. Batson says that the final blend is looking like 1.00 carbon, .80 vanadium and .80 or so manganese.
...high manganese is not so good for hamon activity.
True, Don. Dr. Batson said that they did that specifically for easier hardenability. The original batch that Dan Farr and others tested apparently did not have that much manganese and only fully hardened in water/brine or FAST oil. The original mix apparently acted like your W2 in moderately fast oils like Tough Quench. Dr. Batson said that they also tried a little bit of chrome in the mix, but the increased manganese apparently worked better. Glad to hear that as I am afraid of chrome...lol. So perhaps I will save your W2 for special stuff and use Aldo's 1084 and this stuff for regular knives.Sounds like a great knife steel. But the high manganese is not so good for hamon activity.
Don,
Is there a max amount of Mn below which a person gets distinctly more hamon activity? Are there other factors involved?
Mike
http://www.diehlsteel.com is the only place I have found it. I've had several customers ask for it. Don't know about now. Good luck.
Don, is that 1086M the stuff Howard had made up?
This site has some bad info on W2 and W1.
1.00% Vanadium in W1
Chromium and Tungsten in both![]()
Yep, I've acquired a bit from Howard over the years![]()
Everything you see, hear and read about W2 and other low vanadium simple carbon steels like 1086M seems to support the comment that is attributed to Don Fogg that W2 is the ultimate bladesmiths steel. It has small grain structure, doesn't air harden, gets scary sharp and stays that way and is almost as tough as 5160 or L6. It seems that the trick is getting any to begin with and getting batches like Don's where the carbon isn't up in the 1.5% range where it would be rather difficult to harden using our "roll your own" methods. The Crucible stuff sounds really interesting. Tough to get a hamon, maybe, but i wonder if it is deep hardening enough that you could marquench it? That would be nice.Most of the W2 I've been using has 1%C, .21V, .24Cr, .37Mn, and .44Mn.
It's been producing some very active hamons, but probably wouldn't if the
Mn. were much higher.
The new stuff from Crucible sounds like an excellent performer, though,
and I'll be eager as a kid at Christmas to try some.
