So if I wanted all of the balde coating off ( which I don't ) I could just use scotch bright and get it so the blade has a satin finish??
Thanks again for you replies
Matt
you could, but way way easier to buy a can of paint stripper at the hardware store. works way faster, much less effort. the hand sanding comes in after the coating comes off, if you want it extra shiny.
i use jasco paint stripper.
1) wear rubber gloves, it's nasty stuff
2) i use a baking sheet, cover it in aluminum foil as my work area (edges on the baking sheet keep my mess contained). but just a sheet of aluminum foil on the ground would probably work fine. pour some out on the foil, set your knife in it, pour some more on top. doesn't take a lot, just need to cover all the coating you want to come off. doesn't harm the edge at all. only impacts the coating.
3) wait 1-8 beers. depends how many you can put away in about 15-20 minutes
4) get a paint scraper. minimal chance of scraping the metal on the blade if you use a plastic one, i've used metal ones and razor blade scrapers carefully before and been fine. it will come off very very easily. it's probably actually bubbled off the blade on a lot it already.
5) wash the blade off after all the scraping. scrub away at the edges near the handle to get the remnants.
you may be done right there, you might want to really satin it up with some hand sanding.
--if/when you get paint remover on your hand/arm, you'll know it, it's a chemical burn, you feel it in a minute or two. wash well and it goes away.
--don't worry, paint stripper doesn't hurt the handle at all either. coat the whole thing up good so you can get the spine around the handles
--if you want the busse logo to remain visible, use some pcb etchant on the logo before you strip. couple drops right on the logo, let it sit for a couple hrs, wash off. repeat several times. i let the last one sit overnight on that BATAC i posted pics of earlier. it will etch the logo a little deeper into the blade so it doesn't fade with the coating stripping. will only affect exposed metal, so doesn't impact the coating at all.
