- Oct 29, 2005
Hmm I like this idea do you think you can mod the tops blade like that? Scani'ish draw blade and covex/saber front edge?
That is what I did with mine. It works.
Kyle, i got to handle Chance's Trackers at PWYP too. it gave me the fever to try to grind one when I got home. I also "fixed" my TOPS Tracker, but i did it with 180 grit Rhynowet paper wrapped around a file, not the grinder. My results from scratch were less than spectacular but i will tell you what i learned. I think the major difference between the TOPS grind and the Beck grind on the quarter round is this: on the Beck, the cutting edge is kept close to right angles with the grinding belt (blade blank is rotated while grinding the QR) and on the TOPS the draw knife edge is held at constant right angles to the belt and the quarter round is ground with the edge of the belt (blade blank is not rotated). Look at the "plunge" between the front section and the QR on both knives and i think this will make sense.
The tracker guys on BCUSA just LOVE the quarter round section because you can cut really fine, tight curls with your shavings. do they burn any better? i dont know, lol.
also, why the hollow grind on the draw knife portion? a hollow grind adds a degree of difficulty (at least for me) and all draw knive's i have even seen were flat chisel grinds to zero. Just curious.
randy
I reckon an experiment to find the exact angle would be interesting. I have a way of grinding a fairly precise angle. It might be a little bit harder for me to execute it in the draw area and the transition would almost certainly have to be completely hand done with files/dremel. I would be willing to try it this way with goal of establishing a true and slight deeper quarter round area. I would like to keep the edge convex. Perhaps ivan51 would be willing to offer his tracker up to the gods of experimentation for a project like that? I know what grinds I prefer but this might be an interesting project that I could learn from.
