- Oct 1, 2013
Hi Guys,
I've had my KMG for about a year now, it has a vfd is is 2hp on 220. On the flat platen when I use x weight belts I can't tension the belts as tight as I used to when I first got it. I Have to have very minimal tension for the grinder to start up or the motor and vfd stalls. I've tried moving around the motor mount to adjust tension on the drive belt and that doesn't seem to do anything. If I tighten the grinding belts down I sometimes can get it to run if I start it at almost 70% speed.
Anyone run into this issue?
