I didn't want to mess around I used a dab of JB Weld. This is good right?Checked my pivot and while not "loose", didn't take much to loosen it. Removed it, cleaned the threads of both the screw and barrel as best I could, then added some blue loctite and put it back in. We shall see...
I do see its in stock. I could have sworn when I looked awhile ago it showed out of stock. Must have looked at it wrong.Wish I could swing a tuxedo version. I see one on blade hq still. To close to Christmas.![]()
Is that what they're calling it these days?Stop flipping it so much guys![]()
Turned it into a SparremberI didn't want to mess around I used a dab of JB Weld. This is good right?
What you're saying is stop flipping it and start using it. I gotcha. I did use mine today to cut a bunch of caulk off trim so it would tear the drywall.Stop flipping it so much guys![]()
I only noticed the pivot because the blade was slightly off center. Took it apart to clean and oil before applying blue loctite. Ordered a set of skiffs as I had other bearings in cart, going to make a small detent ball ramp when I put skiffs in. Love this knife!Checked my pivot and while not "loose", didn't take much to loosen it. Removed it, cleaned the threads of both the screw and barrel as best I could, then added some blue loctite and put it back in. We shall see...
All screws on it should be the same... T10. but you tried and a t12 fit?I’ve been carrying, flipping, and using my sparrow everyday since it showed up and haven’t noticed the pivot backing out but went to check it today and did notice all the body screws are T10 which is nice and the pivot takes a larger bit, maybe a T12.
It might have loosened a touch as there was a tiny bit of side to side but the blade was still centered. Snugged it a tad but haven't added any threadlocker yet, gonna see how it goes.
I did loosen the tension on the clip a little as it was tighter than I like going in the pocket but all good now. So far overall it’s a great EDC and the blade came very sharp! I also love the stonewash finishes since its a user.
I only had up to a T10 from work handy at that time and just assumed due to a loose fitting bit but after checking again with my Wiha T10 it fits tight in all the screws. (Edited my previous post). Amazing how much more precise Wiha bits are!All screws on it should be the same... T10. but you tried and a t12 fit?
Show off…..My tuxedo suppose to be delivered tomorrow.
