10 TPI for cutting profiles will be a mistake. That's .100" between teeth. The rule of thumb in bandsaw cutting is 3 teeth engaged with the work. You would only engage 3 teeth simultaneously when cutting .300" or greater material. 14 TPI can work but even that is a bit coarse and will mostly have 2 teeth engaged. 20 TPI is pretty ideal.
If 14 is working for you without losing teeth, I would stick with that. A 10 TPI blade in thin steel is going to knock teeth off quickly, and once it starts on a band it propagates quickly.
I'm with him ^
I just tested the edge with my hardness tester. I worked my way as close as I dare go with my diamond penatrator.
First test is about .180 away from the edge to establish a base line of 43rc. Next closest one is .050 and was also 43rc. Then went closer at .035 just inside the dark area and it dropped to 40rc. I then moved even closer at around .020 and it was also 40rc. That's as close as I dare go to the edge as I don't want to mess up my Wilson penetrator. I think people see the dark oxidized area around the cut and think that area is hard. It's not it's just an area that warmed up and not even hot enough to really affect anything except to temper down the hardness of this pre hardened 15n20.
I got my 30 for $900 from Praxair. They don't sell very well too industry outside surgical people who need a portable unit. So I got a deal. I would call weld supply shots and see before paying that much.
That's funny right there, made my day.
I have thought about building a pentagraph that holds the torch and I can trace the template with a little probe. Would make cutting much smoother to trace templates.
JT, take a look at this one and see if these two items are what I should get: https://smile.amazon.com/gp/product/B00K58EC4W/ref=s9_acsd_al_bw_c_x_2_w
https://smile.amazon.com/gp/product...wc_img_huc_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
