Just a quick update. As someone opined some time ago, this blade is a challenge to properly sand and finish. I found another area of the blade that essentially was too thick, so I had to revert back to filing that section and start the sanding all over again.
I'm pretty near conclusion on that, but as close as I get on the edges, I continue to be dissatisfied with the center line. One problem is that sanding the plung areas causes a little crossover at the center line, which results in light 'scarring' of the other side. Addressing that 'scarring' just moves it back to the first side or leaves light cross hatch marks on the center line.
I'm thinking the only way past this is to buff the blade once I get to 1000 grit. I made a preliminary attempt to see if that would work while at 500 grit. The results were inconclusive because I couldn't find the right rouge.
I also bought some cheap steel to use for the balisong style handles. Since mounting those will require drilling holes in what is now the ricasso (something I won't be able to do after HT), I'm putting off sending the blade out until I have the handle pieces made, so I can be sure I won't need to drill any holes post-HT.
Right now I'm trying to process making balisong handles that hold the blade stable during usage, ideally without having to mount unattractive posts in the ricasso. This will probably involve working on preliminary trial handles on a different blade to make sure my design is functional. For that I'll modify the blade that came with the kit (which already has those unattractive posts), since I have no interest in assembling or using that kit knife as it came anyway.
-Greg
