I think you have a nice mix there, except for the carbon. I think it is a little high. you may have problems with cementite forming on the grain boundaries, and at that level, you will have all plate martensite, which may be a little brittle. I don't think you would want to go much higher than .90% C
IIRC, L6 with .75C is practically at the euctoid point, since the nickle will not form carbides, there is actually less iron to mix the carbon with. The Cr and Mo, if they were to form Cr3C and Mo3C, would only lower the available carbon by about .02-.03% Once the Ni is figured in, the iron/carbon ratio is roughly equivalent to a .80 C steel.
If I am off, I hope someone can point it out.
Ken Nelson
sunfishman said:No moly and .60 manganese.
Satrang said:Bohler makes a grade of steel, K600 that is not too far off your recipe except is has a little more nickel and a little less carbon. They use this material for jaws of life tools. Search the web and you can find it.
If you consider that the 1084 @ .89 Carbon and the L-6 @ .75 you should end up with, if don't burn off carbon at .82. That's damn close to where you want to be.(In a perfect world.)
Hey Guy's,
MEANWHILE ....... COME ONE COME ALL! I GOT 1/4" 1084 IN 1" AND 11/2" AT LESS THAN 1/2 THAT $$ PER LBS.(my little plug)
Aldo
