- Apr 12, 2009
"whale spit" had good reviews, but i can say that the singer sewing machine oil is very effective for lubricating joints and pivots, and readily available.
When i oil the joints i also rub the blade and handle wiping the excess singer oil.
If you use wd40 to oil the joints you'll gall the spring/tang interface in the not so long run...it is not a lubricating oil.
I used WD-40 for 20+ years to lube the joints in my knives (dozens), with no such issues. It's definitely a lighter lube than many (oil IS part of the WD-40 mix, up to 25% of it's volume and listed as 'petroleum base oil' in the MSDS), but it can work just fine, used with common sense. Keeping joints relatively clean is 99% of the battle; most anything will work then, even dry.
David
