- Aug 16, 2011
Thought I'd split this off from the long leaf thread.
Anyways, I decided to test out my newly epoxied handle today, well after the 24 hour cure time. I hacked through a piece of lumber in the yard with no problem. It chopped better than my KLVUK, which is no surprise since it is longer and heavier. What was surprising is that the edge was still very sharp! Considering how soft the steel was when I sharpened it, I expected it to be a mangled dull mess.
So having passed that test, I decided to keep pushing my luck and baton the blade through a piece of firewood. After a few strikes, I noticed a split forming in the handle. I wacked the blade a few more times, and it completely cracked
A whole chunk of the handle came out. The tang was still in what was left of the handle, but I was able to pull it out disturbingly easily. The 2 ton epoxy bonded well to the wood, but it popped right of the metal of the tang.
I'm going to take another shot at putting a handle on this thing, but I'm going to take a few days to consider the best way of doing it. I'm definitely not using 2 ton epoxy this time, and I think a bolster is a must. Also, I think a pin in the tang might have distributed the stress to other parts of the handle. I'm also going to make the handle much shorter this time, just large enough to be comfortable. I made this handle the size of an HI one, but this blade is way too top heavy unless you choke up on it.
