- Mar 7, 2001
Just my 2 cents,
I studied on my own the Qi and it's effect on human or inanimate objects. Based on Choa Kok Sui's book on Pranic Healing (He is a Chinese Filipinos, book can be found on Amazon.com) and tested the result myself on the healing power.
I believe the pyramid phenomenon has to do with concentrating fresh good Qi onto the object that yields the effect.
Like leather and rubber prevents Qi flowing, some blade material are easier to be affected then others, thus sort of 'explain' Cougar's finding
I experience that through meditation, the flow of Qi is stronger and cleaner. Yes you may argue it is in the mind but human mind is very powerful and Qi is directed by the mind.
60% of normal people can sense heat/pulse when they hold the imaginary 5-10"diameter ball between the hands and concentrate on the middle of the palm, relax and breathing normally. Further simple proof is that one can push or pull (by simply willing it)to other person's palm and he/she whill know exactly whether it is pull or push. This is not telepathy as telepathy is at much finer level than just the brute Qi flowing in / out.
For those who still don't believe it, no problem. After all, no one can force a belief onto others ..
And BTW, the pranic healing will work less effective if the recipient do not believe it. As Qi obeys the mind, unbelieving mind will block its flow .. I guess ...
Do anyone believe in accupuncture? Till years ago, the 'scientific world' disbelieve its effectiveness and only lately it is being embraced. Also I believe the approach is different: the western science wants hard proof, while the eastern approach is empirical, as long as it works, it is there.
I read also "Tao of Physics" by Fritjof Capra, a scientist and TaiChi practitioner .. that found the end point where East meets West or vice versa
And do you believe light is wave or particle?
When it comes to the truth, no science can claim absolute truth, only "truth as far as our theory has been so far proven" and that "it is subject to change based on next finding" ... remember Newtonian and Einsteinian kinetic theory ?
If seeing is believing, our modern scientists should be very skeptical as they don't see the proof anymore, but through some measuring equipment that in sub-atomic level the reliability goes only so far ..
Cougar,
When you say true North, is it north pole or the magnetic north?
And what is the fomula? i.e. the ration between the base square and the height .. that will give a precise pyramid ..Thanks.
Cougar,
