Quality of modern Case knives
The dullest out-of-the-box (or tube, technically) knife I have ever recieved was my GEC 97. It still had the burr on. Some stropping and it was ready to go. Most of my Case knives have been appropriately sharp, and the only one that wasn't was still better than that GEC (and was also easily corrected).
If sharpness matters to you, you should probably get set up to do some sharpening, because nothing stays sharp forever if you're using it.
I'd rather not have to sharpen a new knife before use, but it really is the most basic element of maintenance. I'd rather have a full tank of gas when I buy a new car, too, but it's not a dealbreaker.
I can feel the hate coming, but I’ll ask anyway. I’ve never used a stone to sharpen a knife, it the Case “pull through” sharpener any good?
Never used it so I can’t say but a fail proof sharpening system is the spyderco sharpmaker. If that’s too much than I have had great luck with the Idahone for half the price.
In my experience, using a pull through, makes your edge concave from the heel forward maybe 1/3 of the blade length.
I’ve wondered why companies hand sharpen. If Ed has a bad day…
There must be a mechanical way to insure an edge without adding cost to the process.
I hand sharpen, so I’m not poo pooing it. But, I’m not trying to beat the clock either.
In general, I think GEC makes some of the dullest out of the box knives I have ever seen. I feel like I have heard "that's how knives used to come so you could put the type of edge you want on them" but I don't know if that's true.
I have always been pretty critical of Case due to quality, and a much bigger fan of GEC. However, I do find myself carry more Case knives nowadays for whatver reason.
If I find a Case I want, I handpick it. If I don't, and it arrives at a lesser quality than I deem acceptable, I send it to Case and get a good one back, usually. Once I traded blade play and weak springs for a slight bit of blade rap, but it was just a little and I don't want the people at Case to start rolling their eyes when they see my name on the address label...
The mini trapper and medium stockman patters are really nice, and I can't justify the price of GEC's 68 stockman since I already have a 35 cattle knife that gets used a lot.
I will also say Case does stag pretty well, you really are playing the lottery with GEC's stag, it seems to be high risk high reward where Case stag seems consistently "good". When you do get a good GEC stag though, it is pretty amazing.
Pull-throughs where the sharpening surface is a couple of ceramic rods are probably not terrible, though it does seem to me like you are moving the steel 90-degrees in the wrong direction relative to the abrasives. The ones with carbide cutters are just shredding your edge, though.
I tell you, it changed my whole experience with what is a "good" or "bad" knife, both for pocket knives and especially kitchen knives, when I put in the time to learn how to sharpen and over time assembled a set of tools for that purpose.
It took some time and intentional practice, observation, and improvement of techniques until I finally got to where it was fairly second nature.
I can now understand when someone says "Who cares if it not sharp when you get it?" What that person is saying, is that they know how to sharpen knives and don't consider it a major chore to do so. I can use expensive kitchen knives, I can use cheap kitchen knives. I can get both sharp, and have the assortment of stones for either kind.
I like my Case stainless steel knives. I have not bought a new one since maybe 2015 so I can't comment on the state of Case knives in 2024. I was used to them coming with a relatively toothy edge with a factory burr.
Most of the time they just needed a good stropping to remove the burr and lightly polish up the toothiness, but sometimes they needed some refinement. That steel actually works well with a little coarseness left. The CV steel is less prone to burr formation and likes a little more polished edge, but you can still get a mirror edge on either with a little time, decent stones, and a strop.
And then you go cut up those cardboard boxes for the recycle bin and that pretty mirror edge doesn't matter that much. That is where the slightly toothy edge works well. So I sharpen enough for whatever job I have in mind for the blade and leave it at that. If I was a whittler or carver I might find a more refined edge better suited to the work.
That stainless steel is a little prone to forming a new burr when used with ceramic stones like the Sharpmaker, though you just have to learn to use less pressure so you aren't "smooshing" the steel quite so much. It's like anything else you practice - if you pay attention and work to refine your skill, you learn the right way to do it. Nowadays I just use a 2-sided Arkansas bench stone, most of the time without oil cause I am too lazy to do the cleanup, and then I scrub the stone with bar keepers friend when it starts to get clogged up with swarf. I don't use a loupe any more to inspect the edges - I can generally tell by feel and by looking at it that I got it close enough.
I save the loupe for use with the hard steel kitchen knives and the multiple passes on progressive sets of water stones when I am really doing some serious sharpening. :) Them 'taters and onions don't really notice anything but the sharpness, not whether the knife is cheap or expensive or how often I have to sharpen it.
Exactly this. The wrong angle is why they can get a knife kinda sharp, but not very sharp, while still taking off a lot of steel.
I have several sharpening systems, KME, Worksharp guided bench stone, workshop field sharpener, lansky, etc. I can take a new Case knife with a factory "edge" and in 15 seconds have it shaving sharp just from lightly honing using the 20 degree guided ceramic rod on the Field Sharpener. It's a very sharp, serviceable edge in no time. GEC take more time/work on the KME, i reckon their factory grinds are quite a bit higher angle. Sharpening my NW Heritage Jack was quite a marathon. Generally I find a 600 grit diamond sharpened edge followed by the strop makes the best working edge.
I'd like to get into more Arkansas stones, but I'm still using systems with training wheels to get some fundamentals down....
Juts bought the black peanut special from SMKW. Flawless!
Why are the peanuts half stop but not the pen knife??
True,but every fishing season all the fishers use pull through sharpeners when fileting a 1000 fish a day,me at my age I just gather the heads for the pickerel cheeks,which I had a feast of today.
I have been researching the case 6347pu and 6318pu and from what I can see the last one was made in 2012 but I'm hoping to be corrected.im not sure why this pattern is not repeated as it must be a buyer favorite, what am I missing is the punch not as revered as much as I think.
Probably because the Peanut is 2 blades 2 springs whereas the Penknife is 2 blades one spring. Glad to hear yours is a good knife :thumbsup:
Get fällkniven DC4 "lap stone" and you can sharpen any case knife you got. The ceramic side is good for maintaining edge and diamond for restoring edge. Get some cheapo knives to practice with because untrained hand might slip and cause scratches. As you get familiar with sharpening it will become second nature. Also consider getting strop or soft peace of leather to kick of the burr. That forgives a lot of sharpening "errors" and sets the edge straight.
I don't know how to start a new post, so will do 2 things here.
1st to ANSWER the original question, I never had issues with their SS blades.
2nd to ASK a related question: I'm going to retire my Peanut and maybe get a small Stockman.
Does anyone have an opinion on it?
Personally, I wouldn't go for a Small Stockman, find them a bit fiddly due to the proportions, although the 90 pattern is OK. Why not look at one of their excellent Medium Stockman? Compact in the pocket, not heavy, easy to handle.
I'm pretty sure Old Hunter Old Hunter could make some excellent suggestions for you :cool:
I have a large Buck 307 for heavy duty, but think a sheepsfoot is a nifty thing to have. 2 1/2 to 3 inches closed is perfect for me.
With modern Case knives that 2-1/2" to 3" OAL gives you the Case 6333, 63027, 6344 and maybe the 63087 (first four from left to right) to pick from. OH
