- Jul 9, 2019
so I’ve made a vertical quench tank from a 4 x 6 x 48 piece of rectangular steel tube welded to a 12 x 12 plate for a base
The issue is I’m a noob at welding and the seal is not 100%.
It’s actually better than I was expecting, and when filled halfway with water it took a couple minutes before I started to see a film of moisture slowly spreading from a couple spots. With the pressure of 24” of water in the pipe I was expecting actual squirting, or at least trickle.
I don’t really want to try piling more weld bead on there, I doubt it would work actually. There’s a good bit there already.
I could grind away a lot of the bead and re-weld, but the leak is so minute I thought I might save time and trouble and simply pour 3 or 4 oz of epoxy into the tube and let gravity do the rest.
So, my QUESTION is, will Parks 50 react in any way with epoxy that would dissolve it and contaminate the oil, or cause the seal to be compromised?
If yes, is there another sealer that would work better?
I have visions of 5 gallons of parks 50 slowly leaking out over night
