- Jun 11, 2006
You know I don’t mind 6013 but it can be picky. It’s not a drag rod like 7018 and it’s picky on angle. If you don’t hold a steep enough angle the flux will run around and be caught in your puddle creating bug holes. A little trick is stainless rod. That stuff lays down like butter and is not picky about the base material. But generally if it’s not anything structural I will just run 7018 around it. 7018 does not penetrate real great and if your welding up a weld prep 7018 will let flux under it. You should first fill with a 60 series like 6010/6011. This rod will burn deep and will fill the prepped area and not trap flux underneath it. Then cap that with 7018 and your golden.
