My fixed blade knife right now is a Mora. I love it, but I baton wood a lot when making fires, and after learning that it's not a full tang it sort of worries me that I will break it. So now I want a knife with a full tang.
I'm not looking to build a cabin, just process fire wood. A knife should be able to do this fine.
to clarify: I meant I wanted a knife that would hold up to the stress of it. I don't plan to spend hours every day splitting wood. I just don't want the knife to break on me when I need to split wood because it's wet on the outside.
From your first post it sounded like you would be doing a lot of batoning.
There is one advantage towards splitting wood with a knife instead of a hatchet. With a knife you hold the dangerous part, the edge, on the thing you are to split and apply force to the whole thing. If you for any reason miss, the baton is not that dangerous and the knife itself does not have much momentum to do any serious damage. With an axe you both have to aim and hit at the same time.
I do not swing a hatchet at the log when splitting small wood. I stick the hatchet in the wood and then swing the wood and hatchet as one. I strike the wood on a stump or some such and let the wood do the work.
I had never heard of batonning before joining this and another knife forum. If I am stuck with just a knife and I need to split some wood I will try it. If I am going out camping or otherwise know I will need to split wood I will bring along my hatchet.
I also understand the desire to carry minimal gear and get the job done. I sometimes carry to much stuff. To each his own.
