So I started my first knife with a 01 Tool steel sheet 18 in.x 2 in.x 1/8in. I cut out the knife with a power hack saw, and center punched where the holes for the handle will go. Then, I filed the edge and I will finish doing that to get a good bevel. My question was, what are your thoughts about what I have done and how I should move forward with making the knife? Anyone with past experience with this steel or handle material? I plan to use 2 goncalo alves wood knife scales for it. Could you explain how to easily heat-treat a first knife with 01 steel? I have a gas forge, if that helps. Also, I just bought some sandpaper with grits, 60, 100, 150, 220, 500, 1000, 1200, and I was wondering if I should use that or how you have finished a knife.
Thanks in advance, I know I have a lot of questions. I am pretty new to knife-making.
Phil
