powernoodle
Power Member
- Jul 21, 2004
Being a fan of the old Voyager series, I had to check out the new 2011 flavor. The 2011 large Voyager has the look and feel of the old series, albeit in a different configuration. Gone is the flat, rectangular shape, and in its place is a more ergonomic configuration somewhat reminiscent of the Recon 1. This new version seems to grip your hand much as does the Recon 1, and while their are notable differences (G10 vs. "grivory" being one), the two knives clearly come from the same bloodline.
2011 CS large Voyager, top. Old version bottom. Note the torx vs. riveted construction. 4" blades on each. The new Voyager sports AUS 8A steel and (apparent) full flat grind construction.
Notable differences, in addition to the grippy scale shape, include the addition of the awesome Tri-ad lock. Its rock solid, and seems indestructible. Gone is the triangular raised pattern imprinted in the "grivory" (read "plastic") scales, and in its place are a series of raised crosses very reminiscent of the German iron cross. Whereas the old Voyager had only one clip position, the 2011 version accommodates lefties - but its "tip up" only. The clip (not shown) is standard CS and very functional, though I had to tweak mine a little because it was so tight. I also sanded down the grivory under the clip, as I do with every CS knife.
Gone also is the polished blade finish, which is now replaced with a light stonewash. I prefer the old polished look, but thats purely subjective.
Note the "iron cross" motif of the new Voyager, top. The lettering on the new version, being a superficial stamp rather than ingraving, is not an improvment. The new version also is assembled in Taiwan, as opposed to Japan with the old version.
Size comparo: top to bottom - 2011 large Voyager, tanto Recon 1 and 2011 linerless Lawman.
The 2011 Voyager was $52.19 shipped from Amazon. Better prices may be found as this one become more available. But at this price, and taking into account its ergonomic design, solid construction and killer Tri-ad lock, I consider it a good value and a solid contender in the heavy duty EDC or work knife category. 3" and 5.5" versions are also in the pipeline, as well as half-serrated versions.
