******* PLEASE USE COMMON SENSE AND CAUTION WHEN USING THESE CHEMICALS AND READ ALL SAFETY PERCAUTIONS.... THESE MATERIALS ARE CAUSTIC AND CAN CAUSE SERIOUS DAMAGE TO YOU IF NOT USED PROPERLY*****
Sure..
Here is what I used..
"Dremel"
"Polishing pads"
"Gun Blue & rust remover" (firearms supply or sporting goods store)
"Naval Jelly" rust dissolver metal prep.. (Lowe's, Ace, or Home depot)
"Q-tips"
"Blue Magic" Metal Polishing cream (Auto Zone)
"Safety Glasses"
First Use a good degreaser cleaner to clean the blade off, I used Dawn dish soap and tooth brush.. then I used a Q-tip to apply the Gun blue remover in a stripe pattern.. let it set for about 5 minutes then rinse off in hot water..
This left a darker grey finish.. So then I applied the Naval jelly with another Q-tip over the same spots.. and let it set for 20 minutes.... And rinsed it with hot water..
This almost got me down to the bare metal past the black oxide coating.. but it was still kinda darker than I liked..
So I used another Q-tip to apply the blue magic metal polish to the areas and used the dremel and polishing pads to buff them out .. several times until I acheived what I have here..
Hope this helps..
There are other ways of doing this Like masking or making a stripe template and bead or sand blasting the coating off.. If I had access to this method I would have done that instead.. leaving a non glare finish.. but this works for me..
Take Care
~Jeff
