If I may ask, what are "savards?"
Heheh, I believe it is a French word (?) which loosely applies to someone who professes expertise in a certain area. "Wiseman", "Expert", "Guru" etc would be similar I suppose.
In response to Rat Finkenstein, you are correct. I have limited experience with machetes in terms of what they are meant for. I live in the Boreal North, and I don't often have the opportunity to slash soft undergrowth or thickets with a Machete. The Machetes I have used may prove quite useful in the rainforest, but not so much in a forest of pines, hardwoods, cedars and tough shrubs. I have found that affordable machetes
dull quickly and bend when striking anything solid. I used a $7.00 machete to carve up an aspen poplar to try and build a shelter once, and it did the trick, but the blade was in real rough condition afterwards. By way of comparison, I also did the same with a rope saw that was stuffed into the handle of a $5.00 mail-order knife, only the rope saw was quicker and didn't compromise the knife when it finally broke. I have found that military machetes are well rounded for use in the boreal parts of North America. I have seen some for as little as $30 (dull and pitted, however), and some for as high as $200.00. Since a machete has no pointed tip, it is difficult to use for refined works, and beyond this, stabbing or etching is not an option. Also, the generally crude handle often leaves blisters on a bare hand. But, enough about machetes, not many folks class them as well-rounded multi-use tools anyway (rainforest farmers maybe?).
QUOTE by Rat Finkenstein:
"Airing a show that would encourage people to invest in a dangerously unsound and overpriced knifelike object would be a big step in the wrong direction- "It must be good, I saw it on tv"... "
Airing a show to suggest that a knife which is
proven inferior, or "dangerously unsound" be recommended would indeed be folly. I certainly have no intention on buttering things up, just using the knife myself to show others how it goes, and we'll see what happens. As I stated in my previous post, I have had good luck with these kinves, no breakage, good reliability, and decent functionality. If it breaks on me, well, that'll be in the clip too. If not, then that's how it goes. I certainly won't backpedal and overdub just to make a certain knife look good, c'mon man, heheh!
There has been little or no evidence so far to suggest that these knives are "dangerous" as you say they are. I don't think this is being misleading in any way on my part, but instead simply being informative. Until someone documents the actual use of the knife, without bias, there is no substantial ground for discredit. I too admit I speak prematurely until the test is done, but I have actually tested these blades to what some may call a 'limited extent' (shelter construction, fire construction, accidental water submersion, practical durability etc), just not yet in a
real survival scenario where I fear for my life. When I bring this unit out, I will of course have more than enough tools to get me through safely shouild it fail, but I will honestly try to use the Rambo as much as possible and really put it through the ringer. Results will come, since I expect to try this in late summer to early fall in the interior of British Columbia Canada.
In any event, I wanted to come to Bladeforums since it was recommended to me by a few others based on the level of maturity and level-headedness of the members. So far I am quite impressed, people here are quite knowledgeable and treat members and guests alike (even newcomers such as myself) with respect. I look forward to future discussions with all here, and I am certain I can learn a great deal of knowledge from you all. Quite the nice relief after having visited countless other forums where people use profanity on a constant basis and go out of their way to insult others just because opinions vary.
Cheers folks,
Commander
