- Aug 20, 2013
Well-after several very unsuccessful attempts, I still can not get decent edges on my knives.I believe I'm literally doing everything by the book (John Juranitch's Razor Edge book of Sharpening)-getting a burr formed along the lenght on both sides, switching to the fine side of the hone and then taking light even passes at a slightly raised angle.
I'm using a cheap Smith&Wilson diamond coated hone from Walmart-as there's no hunting stores nearby (well there is-but ironically, there selection was even worse), but I assume that's not the problem as it removes steel just fine. The blade can not push cut paper, seems to be an excessive amount of friction when cutting cardboard and light plastic and material sticks to the edge. What could be the problem here, if this question is even possible to answer?
I suspect that another, finer stone would help with the later problem-but I believe it still should be better then it is now.
