Sounds like an awesome time!!!Sorry no pics from me today, I was keeping time for the cut
Bennie and Sue boo kicked ass
Ben put down a blistering time and had the perfect run
Beer.... hanging out withdericdesmond , Bennie Sue boo and all the other cutters was so much fun!!!!!
I need to get my hands right so I can participate next time!
It was!!!!!Sounds like an awesome time!!!
You know the guy is a baddass when he is swinging a blade with a cross in the butt of the handle!
Dude Ben raged today!You know the guy is a baddass when he is swinging a blade with a cross in the butt of the handle!
That looks like so much fun.
Shouldn't be that expensive, I've deleted my fair share of super duties and rams and they're usually around 2-2.5k depending on if you buy the lifetime support pack with all the tunes or a single tune. I know the '22's require a '21 and down engine controller since they are encrypted but wasn't sure if they've moved passed that cause they're deleting '23-'24's now.I wish it wasn’t 4-5 grand to delete these newer trucks.![]()
I think that Elmax doesn't have the good reputation that it deserves because a lot of makers didn't do a good job with it.
Magna cut is going to catch this even worse. It is a fantastic outstanding steel, but it is tempered so low that many, perhaps even most, makers and manufacturers are going to burn the edge sharpening it. And perhaps even grinding it to shape in the hardened state. And they will deny it deny it deny it and lie to themselves that heat at the edge when sharpening is a problem because they don't ever feel the blade even get particularly hot. Just remember that an instantaneous rise to a thousand degrees .005" up the edge (The part that actually cuts) will raise the temperature of the knife by one degree at your fingertips. (I did the math once) You'll never feel it. And so people deny it is a problem. There's going to be so many people doing a bad job of magna cut (grinding it to shape and also sharpening it) that I predict it is going to suffer some pretty bad blows to its reputation due to the incompetence of manufacturers.
Well !… I never
Just tested. DEK 3 fits in a Pirtle DEK 1 sheath but there is no retention, it just sits inside and will fall out if turned over.Hey does anyone happen to know if a Dek3 will fit in a dek1 pirtle sheath? Looks like it will and I know the retention may be loose as the dek3 is thinner but see more dek1 pirtle sheaths up for sale then dek3 so about to pull the trigger just curious if anyone has tried? Thanks
aww brothers from different mothers
Thank you! That was the one thing I thought would be the caseJust tested. DEK 3 fits in a Pirtle DEK 1 sheath but there is no retention, it just sits inside and will fall out if turned over.
