Random Thought Thread
Does anyone else wonder if recent tweaks to Delta-3V might somehow enable another run of DEK-3s with a lower reject-to-creek-bed rate?
Not actually knowing what the problem with them was it's hard to make an educated conjecture, but hey, a guy can dream...
IIRC, the higher did-not-pass CPK's standards was related to the Magnacut iteration, not the D3V versions. Additionally, the hollow grind was not cost effective in terms of resources and man-hours because there is only one Mark at CPK who does the HG.
As far as Magnacut goes, there were some initial issues with anomalies showing up on blades' surfaces which Nathan did not elaborate on (some information we are just not going to be privy to) but this was not just on CPK's. I remember a question in here posed by Josh at REK asking about his own issues. Whatever those (cosmetic?) issues were, perhaps they got amplified with the satin finishes which both CPK and REK had offered with Magnacut. I don't know about REK but we do know that the CPK heat treat with Magnacut is also slightly tweaked but as Nathan had stated previously, not significantly that divergent from the industry standard HT.
I always reserve the right to be completely BS'ing, because this is what I usually do!
Fake Zebras: China vs Gaza.
And some of you may know, I've been making some pretty good knives for a long time now.
And the knives I make now are the best knives I've ever made.
We started out making tweaked D2 that initially caused a lot of arguments and drama here amongst other makers but it eventually set the industry standard.
And we started making tweaked 3V. At a certain point, when our resources allowed us to, we finalized and formalized the best tweak that was fully optimized and, to differentiate it from previous tweaks, we called it Delta 3V, "Delta" indicating change. It is indicated as 3V inside of a Delta triangle.
We have capabilities and resources now that I never had access to before. And, buying the entire billet of material, we can have it any way we want it and we have been taking advantage of that to offer better optimized materials. The Delta 3V we produce today is the best we have ever made and I believe it is the best in the entire industry.
It is my sincere belief that we make the best knives of their kind in the world.
We've been doing some more development work over the winter, as we do, and this winter I decided to revisit 3V. This time with deep pockets and access to people and capabilities and steps of the steel production process we've never had access to before.
One thing that strikes me about our development process is, years ago we changed from 20 DPS in the process down to 18 in order to make differences more obvious.
The cut testing I was doing today, I really needed to go narrower than that to see any difference because nothing was causing any meaningful damage.
But anyways, after cutting a small mountain of cardboard, and pine and whittling cuts in Osage orange, it took not just bright light and magnification, it took a proper stereo microscope to find any differences in edge loss between the samples because it was difficult to find any. 20 years ago this would have made my head spin. We really are living in the Golden era of advanced metallurgy.
However the difference became more apparent when we started chopping Osage, carving the slivers off of the nails, and chopping nails and bolts which is where some of the difference starts to show.
So anyways, this is a long way of saying we've spent an enormous amount of time and money making tweaks to a wide range of variables to provide a product that I can almost guarantee you will never notice the difference between it and the Delta 3V we all know and love.
Delta 3V is really really good. Trying to improve upon it feels like trying to move a mountain.
So, after a significant investment, the new tweak, which includes a number of significant changes, is practically the same performance. But, for some applications anyways, it is a little bit better. And that was the goal really. If it was drastically better that would mean I hadn't done my job right in the first place. But it really is a little bit better. In some ways. And really, that's all I was hoping for.
You will enjoy slightly better edge stability in rough use which will equate to slightly better edge retention. And it only adds about $5 to the cost of the blade, although it does require purchasing large amounts of material at a time. Which isn't a problem, we already do that.
You would never notice a difference without controlled side by side testing. Which is not disappointing to me. If there was a big difference, that would mean that I did it wrong the first time.
Here's a cool picture from the development process, on the 18 DPS test samples. (20 DPS would not show much damage).
This tweak is not just to the heat treat, we have made small changes that go all the way back to the first steps of the steel making process. This would be analogous to a chocolatier controlling the production of a cacao plantation.
We will be offering this tweak on some of our Delta 3V offerings in the future. Patterns where I feel the tweak would be of benefit. The first pattern that will be available is going to be the Field knives. You should check it out, I can almost guarantee you'll never notice a difference.
Hello! Is the first available FBFK please?
Me and the boy are taking up a new hobby!! We are officially gold miners! Went to the gold show this morning and met Carlos from Gold Rush White Water. Got a portable sluice and pump. View attachment 2792645View attachment 2792646View attachment 2792647
Amazon came by this morning also and brought my new hobby RC truck. It’s all metal besides the truck body, real 4wd, oil filled shocks, and goes 50 mph hahaha Check out the motor! Brushless with a 17g gear box, metal gears and drivelines, and 16 real metal bearings throughout! 😍🤣🤣🤣 I’m such a big kid 🤣🤣🤣View attachment 2792655View attachment 2792656
You’re racking up the hobbies and including your son with you, good on you Josh ❤️👍
