Rumor has it they are finally going to begin to transition to S45VN on all new blades....
As we're well aware of though, the steel is only one part of the equation. Some (many?) knifemakers don't bother to maximize the steel's potential with an optimised heat treat.Rumor has it they are finally going to begin to transition to S45VN on all new blades....
Bob and Justin sightings within a week of each other!?![]()
Ivan is the missing one, otherwise there’d be a Ménage a Trois![]()
"Hat trick" "Trifecta" "Triple Crown" - you couldn't have gone with one of those?
I designed this knife and spec'd S35VN. It's hollow ground, .0175" at the bevel transition
although my use for this knife is more general, it's designed with an emphasis on skinning and quartering which is why the edge bevel is so acute and why it's so thin at the transition
some of you may know that I tend to be a little rambunctious in the use of my knives and particularly those which I deem prototypes. As such, this knife saw some shit
Of particular note to me, wrt the steel I selected for it, was the knot test. You can test the flexibility, ductility and brittleness of steel somewhat with the brass rod flex test. This provides little feedback wrt how the steel responds to impact, however
what I do is find a section of tree around the diameter of my wrist, with knots, and skin it. When I get to a knot, I use as much force as it takes to get through it. The grain goes all different directions, putting stresses from all over the place on the leading edge of the blade. The hardness within a knot of also variable, and there is often abrasive deposits in there, depending on how fast growing that kind of tree is
in the case of this knife, I pushed the material past its yield point in some spots, but lost no discernible amount of material. Although it exhibited some distortion here and there, the cutting edge itself is intact
cutting other material, like firehose, shows pretty clearly how abrasion resistant the material is, although polishing the edge bevel is a good way to gauge that and has the benefit of making the knife look a little nicer without messing anything up
anyway, in my experience, S35VN is top notch cutlery steel when heat treated correctly
https://bladeforums.com/threads/shamu-loriendesign-prototype-by-charles-vestal.1403844/Mind showing a side picture of the whole knife? It sure looks good for its intended use from what I can see.
https://bladeforums.com/threads/sha...y-charles-vestal.1403844/page-2#post-16223661Mind showing a side picture of the whole knife? It sure looks good for its intended use from what I can see.
. Do you recommend a maker that does a good job on S35VN, pls?I think well done S35VN
