I doubt anyone in here has one, lol. I hate coatings.
Here is an interesting knife to possibly test for edge holding. They claim 300 times longer lasting edge than ceramic
http://www.aplusrstore.com/product/1499/furtif-evercut-knives
The laser-bonded titanium-carbide surface lasts 300 times longer than standard steel and 5 times longer than ceramic, according to third-party testing. In laymans terms, that means the average user should only need to sharpen it once every 25 years.
Added BD1N, Phil Wilson Custom, .020" behind the edge.
That's a thick edge for Phil's knives. What model was it ? If you don't mind me asking.
Matt
And only 59 Rc? I thought the whole point of BD1N was to give higher hardness ~62Rc vs BD1 steel... Still, it did a little better than some other knives in higher-carbide steels that I'd expect to have similar geometry... *shrug*
Was a test knife.
Something to do with nitrides from the information that I have and was told.
Ken Onion was telling me about it at Blade and spoke with Phil a few times also about it.
Interesting steel.
I won't make it long, but once again Phil made it a homerun from a very basic steel!
0.20" BTH against 0.06" BTH AEB-L both at 60 and a 23.5% difference it is something
We are scoring 440C level edge holding performances (custom) with headroom to improve and far more corrosion resistance with a finer grain, with an inexpensive steel which has similar HT of 440C.
N probably will make very few if any nitrides here, both for its very low amount, the relatively high C content in comparison and, finally, to the fact that Cr nitrides are not that easy to form. Yet the high achievable hardness makes me thinking that we are close (at 63HRC) to 0.6 C in solid solution and no more than 6%-7% overall carbide+ (in case) nitride content.
Also N has some effects on hardness as far as corrosion resistance.
http://www.totalmateria.com/page.aspx?ID=CheckArticle&site=kts&NM=202
Bottom line: with less than 1%C, >15%Cr and 0.5%Moly I would HT at 1066°C just to avoid M23C6 Cr carbides, which take C and Cr away from solid solution.
http://cartech.ides.com/ImageDispla...ss1.gif&IMGTITLE=Effects+on+Hardness+(1+of+2)
http://cartech.ides.com/ImageDispla...ss2.gif&IMGTITLE=Effects+on+Hardness+(2+of+2)
...We are scoring 440C level edge holding performances (custom) with headroom to improve and far more corrosion resistance with a finer grain, with an inexpensive steel which has similar HT of 440C.
HT it is everything, a super steel badge alone is good for marketing departments alone [emoji49]
Avoiding these knives has become second nature to me...
I respectfully disagree with this statement. Heat treat, edge geometry, and steel composition all contribute to the ultimate performance of a knife. If heat treat and edge geometry are equal as between two different knives, the steel composition of each blade will play a significant role in determining which will cut longer.
As far as avoiding knives with blades of a particular steel composition, to each his own.
You twisted my statement mate
I'm not avoiding production blades with a super-steel by standard, should you take your time to read all of my well documented posts in this thread you'll soon find out what I meant to say.
Back to facts: by Jim's results a simple straightfoward no-nonsense BD1N blade at 58 with lot of headroom to improve (it can reach 63) outguns by more than 31% the hyped and uselessly expensive Sebbie in S35VN with nearly same TBE, and it did at a cutting test that favours abrasive resistance, where MC V based carbides should excel. Period. End of story.
The metallurgical reasons behind that are quite clear to me AND I tried to share my knowledge in this thread.
Of all the known brands I know of using super-steels from CTS-XHP to S125V and consequently ask a steeper price for that, I currently trust two: Cold-Steel (Ultimate Hunter) and another one from Italy which I'd mentioned already here.
Why? Please read my former posts
So in the end this definitely recalls once again my shooting range experience, where another shooter tried to convince me that 50AE was better than 45ACP.
In the time he was slapped down (nose smashed and bleeding) trying a double tap and striving to stand up again I put all of my 13 rounds where they should have been put.
50AE can be better in some instances, but it needs higher skills![]()
