Big difference. I have been using spyderco brown rods...about 400 grit to finish my edges and had great results.
Same here. M390 still amazes me at how aggressively it cuts at that lower grit finish
Same here. M390 still amazes me at how aggressively it cuts at that lower grit finish.
So...I wonder what edge would favor S35VN performance...
Same, coarse edge.![]()
Jim,
The coarse edge vs. polished edge is an interesting conversation. What I want to know is if you start with a finer edge does it develop into a "coarse edge" after some use? That was always my assumption, but it seems as though that is wrong if a coarse edge can outlast a polished edge of the same steel. Can you explain that farther?
I too am curious as this makes me wonder how my strop brings an edge back?
Damn it Jim. I just figured out why water is wet and why women have secrets! I was so close to understanding the riddle of steel and the origins of the universe when this question comes up.
Jim,
It's because the edge is more aggressive and efficient at cutting so it takes far less effort (pressure) to make the cuts through the rope, and or most other things as well.
Think of a serrated blade, it will keep cutting for a very long time vs a non serrated blade.
I've always wondered how a blade would perform with one side polished and the other left at about 320. Been meaning to try it
If you could, put "coarse" vs. "polished" in terms of capability to push cutting phone book paper, shaving arm hair, push cutting tp, and so on. I use a sharpmaker and can shave when I am done, but don't really know if that is "coarse" or "polished."
A sharp edge will do all of that, polished or coarse, except maybe push cutting TP.
Closest I've gotten to push cutting TP with a coarse edge was with quite a bit of stropping, and setting the blade about 15 degrees (vertical almost) from the hanging TP.
This was done with S30V@60.5 HRC.
Not exactly "push cutting" in my mind but about the closest I have gotten.
I always assumed that stropping a lot would take it from a coarse edge to a polished edge. I am beginning to think I have never really had a true polished edge. I have the regular fine stones on the Sharpmaker and not the UF's.
I feel like I am missing something. After seeing the results I decided I wanted a coarse edge and thought I would have to stop at the medium stones or something. Now it seems as though a coarse edge is all I have ever done. How do I tell?
